09-16-2010 11:56 AM
Hello group,
Just joined our new Ciscoworks server to our ACS server per the documentation and everything went fine except for the device import from LMS to ACS. Anyway, I have gone through and added a bunch of our devices to ACS manually and now they show up in CS, RME, etc. However, there is now a disproportionate amount of devices that are not in ACS versus devices in ACS.
My question is simply, can I remove those devices that are listed as "Not configured in ACS"? I tried to use the dcrcli command from the LMS server, but I get an error resembling a permission denied. Is a purge of devices possible?
Many thanks in advance,
AJ Schroeder
Solved! Go to Solution.
09-18-2010 11:31 PM
The only way to purge devices in DCR not in ACS is to temporarily disable ACS integration. Then clean up DCR, then re-enable ACS integration.
09-17-2010 12:58 PM
Here is the error that I get when trying to remove devices from the dcrcli command (this is with the local admin account):
Exception in thread "main" com.cisco.nm.dcr.DCRException: Authorization Failed
at com.cisco.nm.dcr.LocalDCR.getMatchingDevices(Unknown Source)
at com.cisco.nm.dcr.DCRProxy.getMatchingDevices_DIRECT(Unknown Source)
at com.cisco.nm.dcr.DCRProxy.getMatchingDevices(Unknown Source)
at com.cisco.nm.dcr.DCRcli.performDel(Unknown Source)
at com.cisco.nm.dcr.DCRcli.start(Unknown Source)
at com.cisco.nm.dcr.DCRcli.main(Unknown Source)
I also tried with the system identity account and got rejected as well:
Error in Delete Device: User is not authorized to perform the task on device.
Hope this helps,
AJ Schroeder
09-18-2010 11:31 PM
09-20-2010 12:51 PM
That worked as you described, now I have a database that is "in sync" with the ACS database.
Thank you!
AJ Schroeder
