Computer ip from router on a stick
eXPlosion
why PC-A PC-B and PC-C in packet tracer are not receiving IP from router on a stick Perth.
https://drive.google.com/file/d/1NkxXqM1dIdylQ4lN4MiBP74-LEIMBnlg/view?usp=sharing
6 Replies 6
Martin L
So far I see following issues (* are critical):
* S1 is connected to wrong port on Router; it should be Fa0/0, not Fa0/1/0
you should have dhcp address exclusion on router to exclude IPs of router from dhcp pool
missing vlans on l2 switches  - switch to trunk vlans must have vlan x in database,
something wrong with etherchannels -  missing some of configs for etherchannels ? only 2 switches doing it or all 3 ?
* Native vlan mismatch between router and a switch
Regards, ML
**Please Rate All Helpful Responses **
pmckenzie
Level 3
Level 3
as @Martin L  says you need to provide you routers address in DHCP and exclude this address from pool.excluded.PNG
As to you Ether Channel well they are non existent.
Here is a lab from Packet tracer people on how to set them up
https://www.packettracernetwork.com/labs/packettracerlabs.html
There are worlds out there where the sky is burning, where the sea's asleep and the rivers dream, people made of smoke and cities made of song. Somewhere there's danger, somewhere there's injustice and somewhere else the tea is getting cold" Dr Who
Here is modified cfg. I connected on a correct port f0/0, excluded router addresses from DHCP, set default gateway in DHCP, added vlan 20, 30, 40 to database, did not touched etherchannel yet, native vlan is 1 by default (I did not changed):
VLAN Name Status Ports
1 default active Fa0/1/0, Fa0/1/1, Fa0/1/2, Fa0/1/3
But computers did not get Address from DHCP
Perth#sh run
Building configuration...
Current configuration : 2027 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Perth
enable secret 5 $1$mERr$/jJFQNiaJSPg5O/2VYM/n0
enable password
ip dhcp excluded-address 192.160.50.1
ip dhcp excluded-address 192.160.50.129
ip dhcp excluded-address 192.160.50.65
ip dhcp excluded-address 192.160.50.193
ip dhcp pool 10
 network 192.160.50.0 255.255.255.192
 default-router 192.160.50.1
ip dhcp pool 20
 network 192.160.50.64 255.255.255.192
 default-router 192.160.50.65
ip dhcp pool 30
 network 192.160.50.128 255.255.255.192
 default-router 192.160.50.129
ip dhcp pool 40
 network 192.160.50.192 255.255.255.192
 default-router 192.160.50.193
no ip cef
no ipv6 cef
ip name-server 192.160.50.100
spanning-tree mode pvst
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.1
 encapsulation dot1Q 10 native
 ip address 192.160.50.1 255.255.255.192
interface FastEthernet0/0.2
 encapsulation dot1Q 20
 ip address 192.160.50.65 255.255.255.192
interface FastEthernet0/0.3
 encapsulation dot1Q 30
 ip address 192.160.50.129 255.255.255.192
interface FastEthernet0/0.4
 encapsulation dot1Q 40
 ip address 192.160.50.193 255.255.255.192
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface FastEthernet0/1/0
 switchport mode access
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial1/0
 no ip address
 shutdown
interface Serial1/1
 no ip address
 clock rate 2000000
 shutdown
interface Serial1/2
 no ip address
 clock rate 2000000
 shutdown
interface Serial1/3
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 password 33
 login
end
Perth#
Sorry I forgot a step that I added.
Your native vlan is not 1 you  changed it to 10
So you need to change trunk link to native vlan 10 as well
Thanks very helpful information.
glad to be of help.
Quick question was this the solution?
