Config Archive probelm
nawas
Level 4
Level 4
Several of my devices (cisco 6500, 4006, and 2948-- CAT OS base) not archiving config and return the following error:
CM0057 PRIMARY RUNNING Config fetch SUCCESS, archival failed for device-name Cause: CM0002: Could not archive config Cause: Device may not be reachable, may be in suspended state or credentials may be incorrect. Action: Verify that device is managed, credentials are correct and file system has correct permissions. Increase timeout value, if required. Action: Verify that archive exists for device
I have checked all of the above, increased the timeout value to 1 min, CDA report OK--
I'm on LMS 3.0.1 on Solaris 10.
Joe Clarke
Post the dcmaservice.log.
