Config issue CPI 3.5
David Ritter
Level 4
Level 4
is it possible to readdress router objects without deleting device and history and recreating with new IP?
Francesco Molino
It's been a while i haven't tried a device ip change on the GUI nor database but i believe (95%) that you still can't do it and you have to delete the old object and create a new object.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
