Config merging - Question.
jokerfmj1
So I have a pretty important part of my configuration that I'm trying to get out to a bunch of remote sites. The best way that I can do this seems to be putting that portion of the config in a file and then putting that file on the [boot]flash of the pertinent devices. Then I want my management tool to go out and execute a configuration merge.
I was doing some research and running a TCL script seemed to be a good option, but from my testing it seems that a TCL script cannot alter the configuration.
So I have questions:
1. Can I run a config merge from file "Importantstuff.txt" to the Running-config? If so, how?
2. Can a TCL script alter the configuration of the device? If so, how?
Also, some of my devices are IOS and some are NX-OS, so no doubt there will be differences there.
Thanks.
Dan Frey
TCL can send configurations commands with ios_config.  starts at config mode and nest other commands to traverse the cli tree.
ios_config "interface $interface.$vlan" "encap dot1q $vlan"
ios_config "interface $interface.$vlan" "ip address $net"
To merge importantstuff.txt to running config = copy flash:importantstuff.txt running-config
