Configuration Change Script
Hello Community
Can someone let me know if there is an script that will show when a configuration change has been made and what the change was?
Cheers
Carlton
andrew.prince
Level 11
Level 11
I know you can write a specific script to look for key words and alert on them like "en" "conf t" "wr mem" etc and send an email alert.
but you should have a look @ the below before you start scripting:-
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtconlog.html
HTH>
Andrew,
I'm also about to post another question asking if there is script that could send me an email whenever a change is made on router and show me what those changes are? Would you be able to help me with that ?
Cheers
Carlton
Hi all,
I no longer need the answer to this question.
Should I delete it? Or should I let it run on?
