02-28-2011 07:57 AM
the customer would like to use SNMP RW access for configuration of ping on Cisco devices. He wants to use ping with the following parameters: destination address, length, number of packets and with DF bit set (it is very important for our customer). Is possible to use SNMP RW and which MIB (OID) is possible to use for it?
Thank you very much.
Roman
02-28-2011 09:28 AM
Hi ,
Extendeing ping with SNMP, unfortunately this is not possible at this point, the only MIB for "ping" features is
CISCO-PING-MIB and it does not contain any OID allowing an extended ping.
Please check the below link for more information:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-PING-MIB
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8e.shtml
I hope this information will help you !!!
Thanks--
Afroj
03-01-2011 12:34 AM
thank you for your info. Is possible to use the RTTMON MIB for this ping?
Roman
03-01-2011 01:13 AM
Hi Roman,
Yes you can use this MIB :CISCO-RTTMON-MIB , I am not sure at what extent it will help you !!!
CISCO-RTTMON-MIB which is only supported in the newer 12.1 and 12.2 IOS versions (and later):
check the below link for more information :
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-RTTMON-MIB.my
Thanks--
Afroj
03-01-2011 01:40 AM
Hi Afroj,
thank you very much. I thought that the RTTMON MIB supports the setting of DF bit, but it doesn't support it:-( So here is no other possibility to set DF bit in the ping request using SNMP, isn't it? Thank you for your help.
Roman
03-01-2011 01:51 AM
HI Roman ,
Unfortunately No there is no possibility to set DF bit in the ping request using SNMP
Thanks--
Afroj
03-01-2011 01:56 AM
Thank you very much
Roman
