configuration of ping using SNMP rw on Cisco devices
ROMAN TOMASEK
the customer would like to use SNMP RW access for configuration of ping on Cisco devices. He wants to use ping with the following parameters: destination address, length, number of packets and with DF bit set (it is very important for our customer). Is possible to use SNMP RW and which MIB (OID) is possible to use for it?
Thank you very much.
Roman
6 Replies 6
AFROJ AHMAD
Hi ,
Extendeing ping with SNMP, unfortunately this is not possible at this point, the only MIB for "ping" features is
CISCO-PING-MIB and it does not contain any OID allowing an extended ping.
Please check the below link for more information:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-PING-MIB
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8e.shtml
I hope this information will help you !!!
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
thank you for your info. Is possible to use the RTTMON MIB for this ping?
Roman
Hi Roman,
Yes you can use this MIB :CISCO-RTTMON-MIB , I am not sure at what extent it will help you !!!
CISCO-RTTMON-MIB which is only supported in the newer 12.1 and 12.2 IOS versions (and later):
check the below link for more information :
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-RTTMON-MIB.my
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&submitClicked=true&mibName=CISCO-RTTMON-MIB#contents
Thanks--
Afroj
Hi Afroj,
thank you very much. I thought that the RTTMON MIB supports the setting of DF bit, but it doesn't support it:-( So here is no other possibility to set DF bit in the ping request using SNMP, isn't it? Thank you for your help.
Roman
HI Roman ,
Unfortunately No there is no possibility to set DF bit in the ping request using SNMP
Thanks--
Afroj
Thank you very much
Roman
