Configure replace issue.
JKOOP
Frequent Visitor
Frequent Visitor
I'm having an issue with auto-replacing a config archived on bootflash. The error it gives me isn't very informational on the issue so I'm not really sure how to troubleshoot.
replace-me#show archive
The maximum archive configurations allowed is 5.
There are currently 5 archive configurations saved.
The next archive file will be named bootflash:/-<timestamp>-16
Archive # Name
1 bootflash:/-Aug-15-22-24-17.277-11
2 bootflash:/-Aug-15-22-25-21.199-12
3 bootflash:/-Aug-15-22-25-35.604-13
4 bootflash:/-Aug-15-22-26-23.398-14
5 bootflash:/-Aug-15-22-27-00.196-15 <- Most Recent
replace-me#show bootflash:
-#- --length-- ---------date/time--------- path
161 4096 May 22 2020 13:24:43.0000000000 +00:00 /bootflash/onep/apps-cli
162 157 Aug 14 2020 22:56:41.0000000000 +00:00 /bootflash/csrlxc-cfg.log
163 35 May 22 2020 13:30:15.0000000000 +00:00 /bootflash/pnp-tech-time
164 59901 May 22 2020 13:30:26.0000000000 +00:00 /bootflash/pnp-tech-discovery-summary
165 8787 Aug 15 2020 22:25:23.0000000000 +00:00 /bootflash/-Aug-15-22-25-21.199-12
166 8787 Aug 15 2020 22:25:40.0000000000 +00:00 /bootflash/-Aug-15-22-25-35.604-13
167 8787 Aug 15 2020 22:26:27.0000000000 +00:00 /bootflash/-Aug-15-22-26-23.398-14
168 8787 Aug 15 2020 22:27:04.0000000000 +00:00 /bootflash/-Aug-15-22-27-00.196-15
169 8787 Aug 15 2020 22:27:31.0000000000 +00:00 /bootflash/-Aug-15-22-27-27.519-16
15098597376 bytes available (493973504 bytes used)
replace-me#configure replace bootflash:/-Aug-15-22-19-58.156-7 time 1
Rollback Confirmed Change: Backing up current running config to bootflash:/-Aug-15-22-25-35.604-13
This will apply all necessary additions and deletions
to replace the current running configuration with the
contents of the specified configuration file, which is
assumed to be a complete configuration, not a partial
configuration. Enter Y if you are sure you want to proceed. ? [no]: y
Error: Could not open file bootflash:/-Aug-15-22-19-58.156-7 for reading
replace-me#show version
Cisco IOS XE Software, Version 16.11.01b
Cisco IOS Software [Gibraltar], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.11.1b, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 28-May-19 12:45 by mcpre
Mark Elsen
- The file doesn't seem to be available on the bootflash.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
JKOOP
Frequent Visitor
Frequent Visitor
Yes, that solves it. I had aggressive archive timers. And forgot to not reuse the command as I would with any other command.
