Configure TLS in Cisco Switch
Sagar4
I want to change TLS version in Cisco switch C2960X-48TS-L. The firmware version installed is c2960x-universalk9-mz.152-7.E9.bin.
Please guide me how to check current TLS version and how to disable and enable particular TLS version.
Ruben Cocheno
@Sagar4
Jump on config mode
Check Ciphers available
sh ip http server all
HTTP server status: Disabled
HTTP server port: 80
HTTP server authentication method: local
HTTP server access class: 0
HTTP server base path: flash:/c2960x-universalk9-mz.152-4.E8/html
HTTP server help root:
Maximum number of concurrent server connections allowed: 16
Maximum number of secondary server connections allowed: 5
Server idle time-out: 180 seconds
Server life time-out: 180 seconds
Server session idle time-out: 180 seconds
Maximum number of requests allowed on a connection: 25
HTTP server active session modules: ALL
HTTP secure server capability: Present
HTTP secure server status: Enabled
HTTP secure server port: 443
HTTP secure server ciphersuite:  dhe-aes-128-cbc-sha dhe-aes-256-cbc-sha
        edche-rsa-aes-256-cbc-sha edche-rsa-rc4-128-sha
HTTP secure server client authentication: Disabled
HTTP secure server trustpoint:
HTTP secure server active session modules: ALL
Viewing available current cipher suites
ip http secure-ciphersuite ?
  aes-128-cbc-sha            Encryption type tls_rsa_with_aes_cbc_128_sha
                             ciphersuite
  aes-256-cbc-sha            Encryption type tls_rsa_with_aes_cbc_256_sha
                             ciphersuite
  dhe-aes-128-cbc-sha        Encryption type tls_dhe_rsa_with_aes_128_cbc_sha
                             ciphersuite
  dhe-aes-256-cbc-sha        Encryption type tls_dhe_rsa_with_aes_256_cbc_sha
                             ciphersuite
  edche-rsa-aes-256-cbc-sha  Encryption type tls_ecdhe_rsa_aes_256_cbc_sha
                             ciphersuite
  edche-rsa-rc4-128-sha      Encryption type tls_ecdhe_rsa_rc4_128_sha
                             ciphersuite
  null-sha                   Encryption type tls_rsa_with_null_sha ciphersuite
To verify what was being offered by the switch I ran the nmap ssl-cert and ciphers script.
sudo nmap --script ssl-cert,ssl-enum-ciphers -p 443 192.168.10.31
Enable only secure ciphers
test(config)#ip http secure-ciphersuite edche-rsa-aes-256-cbc-sha aes-256-cbc-sha
test(config)#ip http tls-version ?
  TLSv1.0  Set TLSv1.0 version Only
  TLSv1.1  Set TLSv1.1 version Only
  TLSv1.2  Set TLSv1.2 version Only
test(config)#ip http tls-version tlsv1.2
To verify, you run the nmap ssl-cert and ciphers scripts. This time only TLS 1.2 is enabled.
sudo nmap --script ssl-cert,ssl-enum-ciphers -p 443 switch-ip
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Hello @Sagar4 ,
Check TLS version on the switch with the following commands:
show ip http client all
show ip http server status
You can change TLS version used by switch with the following commands:
Device(config)#ip http client tls-version <TLS version>
Device(config)#ip http tls-version <TLS version>
Regards, LG
*** Please Rate All Helpful Responses ***
