Configuring Cisco C921 - 4P Help
AlexM445
Hello All,
I am a beginner with networking devices from Cisco. I am attempting to have the router connect to my computer through gigabit port 0 and my ISP to be on gigabit port 5. I have successfully setup a DHCP server and can obtain an ip to my computer, however, I can not reach the internet from it. I have posted my running configuration below, does anyone have any ideas on what I may have missed and why? I am trying to learn, so a detailed explanation of my errors would be very beneficial.
Thank you very much,
AM
Current configuration : 1521 bytes
! Last configuration change at 17:56:09 UTC Mon May 15 2023
version 15.9
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.150.60
ip dhcp pool PublicInternet-Pool
network 192.168.150.0 255.255.255.192
default-router 192.168.150.60
dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid C921-4P sn PSZ27011KMG
redundancy
interface GigabitEthernet0
description Something
switchport access vlan 20
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet5
description uplink to isk
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan20
ip address 192.168.150.60 255.255.255.192
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet5 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp
ip ssh version 2
access-list 1 permit 192.168.150.0 0.0.0.192
control-plane
line con 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
access-list 1 permit 192.168.150.0 0.0.0.63
 change this ACL here
to
access-list 1 permit 192.168.150.0 0.0.0.255
AlexM445
Thank you very much. Both solutions were successful. However, I am wondering why the X.X.X.63 and X.X.X.255 are allowing the connection while the X.X.X.192 failed?
the cisco using subnet or wildcard
in ACL you must use wildcard
the subnet is 255.255.255.192 and it wildcard is 0.0.0.63.
why it important
wildcard include or exclude (permit or deny) the host IP that need to ACL of NATing, in other words if the wildcard is wrong the host private IP not NATing and this why the access to internet is failed.
