Setup Web Gui Interface on 900 Series ISR Router (C921-4P).
klukasik
Hello, I have Cisco C921-4P Router. I have basig config right there thanks to @Georg Pauwen  (ISR connected to the one of the WAN ports and  LAN ports working as a switches). But I want made some other configurations. So here is a question. There is an option to turn on Web Gui Interface for manage this router? It will be much more easier to manage this device.
6 Replies 6
balaji.bandi
Q.  What web-based or GUI tool is available for the 900 Series ISRs?
A.  You can configure and manage the 900 Series ISRs with Cisco Configuration Professional.
try
config t
ip http server
ip http secure-server
check from PC https://routerip
BB
I was thinking about web interface where I can change ssid name etc
Also Cisco Configuration Professional is no longer supported. I can even find it. But like I'm saying looking for web interface of my router where I can easily configure it (like in normal tplink router where I type routerIP etc). This server it's same thing like I will configure it by console.
i do not have any device to test.
check enable http or https as suggested,
BB
I already did. Like I said this http server it's not what I'm looking for. I'm looking for something like this:
https://www.youtube.com/watch?v=PLuOk3BogAo
silviutanasie
I have the same problem. I ordered the router, connected to it via console and started its http server but the interface it provides is not helpful.
The alternative of learning CISCO terminal commands is no go for me since I don't have the time for such an endevour. When I ordered the router I didn't imagine it lacks GUI.
I want to return it but the supplier won't accept it.
