Configuring SMTP on cisco prime 2.2.0
DaSilvaAL1
Good morning all.
In cisco prime we want to schedule some reports to run weekly and then being sent by Email to us.
I have configure a Gmail account, (In order to use their SMTP in prime), and set the parameters inside Prime but it doesn’t work (see the attached print screens).
I can telnet the Gmail smtp server from my PC and get response, also I can configure outlook to retrieve and send emails from Gmail using the account that was created and it works fine… (So I can assume smtp is not being blocked in the firewall).
marce1000
 - Seems like prime can't resolve the dns-names of the smtp server; check ip name-server.... config item in the running-config of prime.
M,
mohammad saeed
Level 5
Level 5
Hi Dasilva, i have the same issue. and my ip name server is ok I can ping google.com from CLI of PI.
Did you solve it?
thanks
Mohammad Saeed
