Connect to my Cisco Switch
Hi Guys
i need some help, i just received my new Cisco 9300 L 48Port Poe and i cannot access the switch to start the config, not even set the IP. i read online that u will need a serial connection. The switch does not have any serial connectors neither my pc.
Can i make a standard crossover cable and connect it to the console port ?
Jaderson Pessoa
Step 1
Make sure that no devices are connected to the switch.
Step 2
Connect one end of an ethernet cable to one of the downlink (non-management) ports on the active supervisor and the other end of the ethernet cable to the host (PC/MAC).
Step 3
Set up your PC/MAC as a DHCP client, to obtain the IP address of the switch automatically. You should get an IP address within the 192.168.1.x/24 range.
Figure 3. Obtaining the IP Address
It may take up to three mins. You must complete the Day 0 setup through the web UI before using the device terminal.
Step 4
Launch a web browser on the PC and enter the device IP address (https://192.168.1.1) in the address bar.
Step 5
Enter the Day 0 username webui and password serial number. Note that the serial number is case sensitive.
Documentation about: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_01000.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Thanks , ive tried that solution but the switch never gives a IP it my laptop i connect to it just gets a 169 address
