EEM CLI pattern ".*" sent to a remote syslog
iogden
Requirement is to send all CLI activity to a remote syslog server/s, the following configuration sends the syslog message to the local device only, useful but i need the messages sent to remote servers, any help would be appreciated.
event manager applet CLIaccounting
event cli pattern ".*" sync no skip no
action 1.0 syslog priority informational msg "$_cli_msg"
TACACS+ already implemented, however due to numerous issues, would be advantageous to have both options working.
balaji.bandi
Not sure what is the device you looking to implement this :
if this IOS XE you have feature archive to logging
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/config-mgmt/configuration/xe-3s/config-mgmt-xe-3s-book/cm-config-logger.html
BB
Thanks BB - Code is IOS-XE, however I need all commands logged, including error messages and partial commands that invoked device help output.
Again, thank you...
Hi BB,
Running code is IOS-XE, however I need all commands log, proposed solution only logs config commands.
Thanks for your reply.
