Console cable - non-serial?
mvoss
Is there a console cable that does not connect to a computer via a serial port? If so, where can I get one? If not, are there any plans to make one?
spremkumar
Level 11
Level 11
hi
AFAIK you can connect the console onto your USB port if you have USB to Serial converter cable and the required driver for the cable.
regds
