Control Plane Policing (CoPP ) SNMP OID
Leonid Voronkin
Hi.
I am trying to get information about Policy on Control Plane by SNMP. According to SNMP Navigator it should be 1.3.6.1.4.1.9.9.166.1.1.1.1.2.5
Router ISR4431 with IOS 16.9.4. It persists in supporting images
But when I try to get information it says "variable does not exist". Does anybody use SNMP to get CoPP information? Could you help?
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
Leonid Voronkin
The question is closed. I found everything I need
Leonid Voronkin
