Cosmetic bug???
yjdabear
TAC says CSCej35942 "mis-spelling oof voltage in SYS-3-SYS_LCPERR3 message." is purely cosmetic. Is this referring to the misspelling or the entire "SYS-3-SYS_LCPERR3:Module 3: Inline Power Module- PS volatage bad: Module needs troubleshooting or TAC assistance"? Should such repeated errors warrant at least reseating the module to see if the error goes away?
Joe Clarke
This refers to the misspelling alone. The problem that triggers this message could be quite serious. I suppose a reseat of the module would be the least expensive thing to try, but it could indicate a bad bpower supply, bad module, or bad chassis. More troubleshooting should definitely be done.
