CPI1.3: WLC Configuration Archive - Failure
artemepishov
Good day, everybody!
I try to make Configuration Archive for Wireless Lan Controller. WLC managed without any mistaces, SNMP v3 and SSH v2 have already configured.
But, when I start Configuration Archive task and check Status in Jobs Dashboard - I always have Failure, like this:
Does anybody know why I can't normally save configuration? Thanks for advices!
artemepishov
In the Jobs Dashboard I choose Configuration Archive Results - Failure and see Fetch Running information:
SNMP: Failed to establish SNMP connection to 10.0.10.101 - Cause: Device is Unreachable. Check the ReadOnly community string. SNMP: Failed to establish SNMP connection to 10.0.10.101 - Cause: Device is Unreachable. Check the ReadOnly community string.
But I don't understand, why Check the ReadOnly community string? I use SNMP v3!
For example, I've successfully got Configuration Archive from c3560G by using same SNMP v3 and SSH parametres.
Does anybody have ideas?
