04-27-2007 03:18 PM
i use cpmDS1DS0UsageTable MIB to monitor how many DS0 are used for each DS1.
But not all active interface are covered. In specific i have 4 E1 interface (two in VWIC0, one in VWIC1 and one in NM):
0/0/0
0/0/1
0/1/0
1/0/0
in the snmp walk i can see only 3 of those interface (no cover for interface 0/1/0). the output of snmpwalk is:
SNMPv2-SMI::enterprises.9.10.19.1.1.9.1.3.0.0 = Gauge32: 0
SNMPv2-SMI::enterprises.9.10.19.1.1.9.1.3.0.1 = Gauge32: 0
SNMPv2-SMI::enterprises.9.10.19.1.1.9.1.3.1.0 = Gauge32: 0
the mapping is:
0/0/0 9.0.0
0/0/1 9.0.1
0/1/0 not covered
1/0/0 9.1.0
Someone has an idea of why one interface is not seen??
Stefano
04-27-2007 06:44 PM
You're not going to get reliable CISCO-POP-MGMT-
MIB support from non AS5XXX platforms. See http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dddf22e/0#selected_message and CSCee16176 for more details.
04-27-2007 11:20 PM
Thanks, now it's clear but i don't find any other MIB that gives the DS0 usage inside the specific E1.
Any idea on which MIB has the same function?? the bug toolkit doesn't report any useful alternative.
s.
04-27-2007 11:27 PM
Depending on the configuration, the ISDN-MIB and the isdnBearerOperStatus object may be of use.
04-27-2007 11:47 PM
That MIB gives you the status of the single DS0. What i'm looking for is the value of used DS0 inside a DS1 (how many DS0 is simultanuosly used).
That object gives wrong information like show isdn active. As you can see from this output 10 outgoing calls are reported as active but no B channel are up (last call was at least 12 hours before):
TXR-VoIP-GW-1#sh isdn act
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out +******7700 +****533136 56030 Unavail - 0
Out +******1783 +****212667 52873 Unavail - 0
Out +******1783 +****516550 57584 Unavail - 0
Out +******7700 +****312778 62156 Unavail - 0
Out +******1783 +****900608 56774 Unavail - 0
Out +******1783 +****534161 60162 Unavail - 0
Out +******1783 +****695111 62620 Unavail - 0
Out +******7700 +****536206 70015 Unavail - 0
Out +******0955 ****893274 57491 Unavail - 0
Out ******3608 ****893274 55732 Unavail - 0
TXR-VoIP-GW-1#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 1
ISDN Serial0/0/1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
Number of L2 Discards = 0, L2 Session ID = 0
ISDN Serial0/1/0:15 interface
dsl 2, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 2 CCBs = 0
Number of L2 Discards = 0, L2 Session ID = 2
ISDN Serial1/0/0:15 interface
dsl 3, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 3 CCBs = 0
Total Allocated ISDN CCBs = 0
s.
04-28-2007 08:31 AM
The other choices for this platform are trying to use the CISCO-VOICE-DIAL-CONTROL-MIB or the DIAL-CONTROL-MIB (e.g. see the callActiveTable), or write a script to parse the CLI, and perform the calculation you need.
For the latter solution, assuming you're running 12.3(2)T or higher, you can use the embedded tclsh engine to build a customer show command to provide this data. See http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a75a7.html for more on TCL scripting in IOS.
