CPU and Memory SNMP trap switch
alfonso.cornejo
Level 3
Level 3
Does anyone know how to configure in a 2950 or 2960 snmp in order to send traps regarding cpu and memory utilization?? I can't find it in the command line or in any document.
Here is the output of the 2950:
Switch(config)#snmp-server enable traps ?
  bridge            Enable SNMP STP Bridge MIB traps
  c2900             Enable SNMP c2900 traps
  cluster           Enable Cluster traps
  config            Enable SNMP config traps
  entity            Enable SNMP entity traps
  envmon            Enable SNMP environmental monitor traps
  flash             Enable SNMP FLASH notifications
  hsrp              Enable SNMP HSRP traps
  mac-notification  Enable SNMP MAC Notification traps
  port-security     Enable SNMP port security traps
  rtr               Enable SNMP Response Time Reporter traps
  snmp              Enable SNMP traps
  syslog            Enable SNMP syslog traps
  vlan-membership   Enable SNMP VLAN membership traps
  vlancreate        Enable SNMP VLAN created traps
  vlandelete        Enable SNMP VLAN deleted traps
  vtp               Enable SNMP VTP traps
  <cr>
Switch(config)#snmp-server enable traps sn
Switch(config)#snmp-server enable traps snmp ?
  authentication  Enable authentication trap
  coldstart       Enable coldStart trap
  linkdown        Enable linkDown trap
  linkup          Enable linkUp trap
  warmstart       Enable warmStart trap
  <cr>
Thanks in advance for your help.
AFROJ AHMAD
Hi ,
for CPU and Memory Utilzation you need to poll the below OID's:
* CPU utilization:
- MIB:      CISCO-PROCESS MIB
version: Cisco IOS Software releases 12.2(3.5) or later
object:     cpmCPUTotal5minRev
OID:        1.3.6.1.4.1.9.9.109.1.1.1.1.8
object:     cpmCPUTotal1minRev
OID:        1.3.6.1.4.1.9.9.109.1.1.1.1.7
object:     cpmCPUTotal5secRev
OID:        1.3.6.1.4.1.9.9.109.1.1.1.1.6
version: Cisco IOS Software releases later to 12.0(3)T and prior to
12.2(3.5)
OID:        1.3.6.1.4.1.9.9.109.1.1.1.1.5
OID:        1.3.6.1.4.1.9.9.109.1.1.1.1.4
OID:        1.3.6.1.4.1.9.9.109.1.1.1.1.3
- MIB:      OLD-CISCO-CPU MIB
version: Cisco IOS Software releases prior to 12.0(3)T
object:     avgBusy5
OID:        1.3.6.1.4.1.9.2.1.58
object:     avgBusy1
OID:        1.3.6.1.4.1.9.2.1.57
object:     busyPer
OID:        1.3.6.1.4.1.9.2.1.56
* Memory utilization:
MIB:        CISCO-MEMORY-POOL-MIB
object:     ciscoMemoryPoolMIB
OID:        1.3.6.1.4.1.9.9.48
for more information ,check the below link:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a94.shtml
I hope this will help you !!!
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Tnx Afroj !!
