Create compliance to find IP helper and replace
tverhoeven
I need to add ip helper addresses to over 100 routers.  Unfortunately these could be on any combinations of sub interfaces.  GI 0/0 , 0/1, 0/0/0 and so on.
Can I find helper address and the add the new one to the correct interface?
omz
are you looking do this manually or scripting?
so .. there are 100 routers with ip-helper already configured?
and you need to replace or add the new helper-address?
you need to first find the interface with helper-address and replace/add on that interface?
interface can be any GI 0/0 , 0/1, 0/0/0 , SVI .. ?
Yes...The SVI are different on all routers.
I was hoping to do this through compliance but I will hand bomb if necessary
