CSM 3.0.1 and FWSM 6500 switch module incompatibility
Hi to all!
I inserted stand alone FWSM 3.1.(4) module into CSM 3.0.1.
During discover policy, it gives me the error about version unsupported.
I know, that I can leave this error, using CSM 3.1.
the error...
Description
There is a major change on device FWSM-ROMA.
The target type changed.
The version on device is: 3.1(4), platform: Cisco Catalyst 6500 Series Firewall Services Module, mode: ROUTER, multiplicity: SINGLE, target type: TARGET.UNDEFINED.
The version in CSM database is: 2.3(1), platform: Cisco Catalyst 6500 Series Firewall Services Module, mode: ROUTER, multiplicity: SINGLE, target type: TARGET.FWSM.L3.
Operation stop
Action
Please verify running device version with the version in Cisco Security Manager database
Recreate device in Cisco Security Manager Database if needed
The CSM3.01 Supported devices document says about that:
Supported Software
Cisco Catalyst 6500 Series Firewall Services Module?Firewall Services Module Software
Release 2.2, 2.3, and 3.1.
The error description says that:
....The version in CSM database is: 2.3(1),...
So, if I can manage 3.1, why the error description says that in the database is stored the 2.3.(1)?
Thanks.
Leonardo
a-vazquez
Level 6
Level 6
Catalyst 6500 Content Switching Module (WS-X6066-SLB-APC) Requires a Minimum Version of 3.1.4 Content Switching Module (CSM) Software in Order to be Recognized by a Sup720.
Please click following URL:
http://www.cisco.com/en/US/products/ps6498/products_user_guide_chapter09186a00806c2751.html#wp1058146
Hi vazquez,
you mean that:
Security Manager 3.0.1 supports discovery of firewall policies only.
So, I cannot deploy rules into theese modules with CSM 3.0.1?
Leonardo
yes I know this answer,
I loaded FWSM 3.1.4 into CSM.
I see it.
But i don't understand how I can discovery policy and how I can deploy policy into FWSM.
Seems that CSM3.01 doesn't mapping the FWSM 3.1.4 SW configuration files.
Documents explain that I can manage 3.1 FWSM IOS SW with CSM3.0.1.
Tks
Leonardo
