CTRL+SHIFT+6 X not working on 17.3
russell.sage
Level 3
Level 3
I am using a Cisco 4321 as terminal server running 17.03.04a using a NIM-16a and octupus cable to Catalyst 9000 switches. I SSH onto the terminal server and then use the menu command to connect to the switches.
menu MYMENU title ^CC
************************    TERMINAL SERVER   **************************
************************         MENU         **************************
      To exit ssh session and return to the menu press
   <CTRL>+<SHFT>+<6> then <X>.  To clear a connection to begin
 a new console session type cls# (where # = the menu item number)
               Type "exit" to return to main menu.
 ITEM            DEVICE NAME
^C
menu MYMENU prompt ^CC Please enter your selection: ^C
menu MYMENU text 1 INX9200-1
menu MYMENU command 1 resume INX9200-1 /connect telnet INX9200-1
menu MYMENU text 2 INX9200-2
menu MYMENU command 2 resume INX9200-2 /connect telnet INX9200-2
menu MYMENU text 3 INX9407-1
menu MYMENU command 3 resume INX9407-1 /connect telnet INX9407-1
menu MYMENU text 4 INXFW01-1
menu MYMENU command 4 resume INXFW01-1 /connect telnet INXFW01-1
menu MYMENU text e Exit
menu MYMENU command e menu-exit
menu MYMENU text q Quit
menu MYMENU command q exit
menu MYMENU command cls1 clr1
menu MYMENU command cls2 clr2
menu MYMENU command cls3 clr3
menu MYMENU command cls4 clr4
menu MYMENU line-mode
menu MYMENU single-space
I only have access to PuTTY 0.76 and CTRL+SHIFT+6 X doesn't kill the session on the target switch and return to the terminal server.  If I leave it the connection timesout and returns to the terminal server.
According to all the documentation I have read CTRL+SHIFT+6 X should work. That is what is in all documentation
odd. Make sure you press Ctrl + Shift + 6, then release these three keys and immediately press 'x' after that. I have also read that sometimes you might have to type '6' multiple times...give that a try.
Thanks for the suggestion but it makes no difference. I have read on certain forums that Putty has an issue with CTRL+SHIFT+6 sequence.
that is possible. You could try TeraTerm, if that is an option for you...
