IP routing command timeout my SSH connection on Cisco 9300
t.ogunwola
Each time i enter the ip routing command it disables my ssh connection . I would have to jump to the switch from another switch.
Any thoughts?
line vty 0 5
login local
transport input ssh
2 Accepted Solutions
balaji.bandi
What i think here, is whether you enable IP routing here or add any other route command.
I would have to jump to the switch from another switch  - << i think you are jumping from another switch and able to login here because both the switches are in the same subnet.
when you are able to log in from a different switch.
then add IP route 0.0.0.0 0.0.0.0 x.x.x.x (next hop IP address)
still issue below config :
show run
show IP route
(what is the IP you trying to connect using SSH? What is the device IP)
and what IP address were you successfully to connecting the switch?
BB
you most probably have "ip default-gateway" command which works when ip routing is disabled. When "ip routing" is enabled, this command can not help and you should have respective route (default route, for example) in routing table.
Add default route, then enable ip routing.
HTH,
We need totall view of your topogly'
Can you share it?
balaji.bandi
show run
show IP route
BB
HTH,
t.ogunwola
@balaji.bandi  that fix the issue!. Thank you everyone
