CUOM Operational Down Alerts
sebastianwagner
Level 2
Level 2
I'm experiencing a little unhandsome issue monitoring our voice gateways via cuom (version 8.6)
Whenever a device is discovered or re-discovered a bunch of alerts are generated:
Se0/0/0:1 OperationallyDown
Se0/0/0:2 OperationallyDown
All and every Subinterface of an E1 is alerted as down, but beside signaling on Se0/0/0:15 they are supposed to be down (unless in a call)
Is that a configuration issue or is cuom not aware of the underlying "voice interface structure"?
That is seen for BRI and PRI
Sebastian
sebastianwagner
Level 2
Level 2
Found it:
CSCua55207
Seems only 2900/3900 using voice interface cards affected due to "wrong" discovery.
To me the given workaround does not work since in CUOM 8.6 the file mentioned is not available
Sebastian
