CUOM with service Monitor
omar_youn
I want to install CUOM version 8 with Service Monitor.
I want to know if it’s necessary to have the sensor Cisco 1040 to use and configure Service Monitor or I can use Service Monitor without the sensor.
Thanks a lot,
best regards,
Omar YUNSI
Fadi Twal
Yes, you can use it without having sensor in your network.
In this case you will add the CUCM as a data source to monitor the calles and CDR records for generating the CVTQ reports.
