Customizing HUM graphs
cmartinvalle
we have HUM 1.2. In all the graphs, the top Y axis value is related to the maximun measure showed by the graph, would it be possible to configure HUM for always showing a top value of 100?
Thanks.
Joe Clarke
No, unfortunately the graph definitions are not configurable. I also haven't seen this question raised before. It might make a good Product Enhancement Request for your slaes team to raise.
Joe Clarke
Hello Joe,
And in the HUM graphs, can I join RX and TX graphs?
I don't fully understand the question.  If you mean change the graphs shown in the screenshot, then no.  If you are referring to something else, then start a new thread, and include as many details as possible.
