CVDeviceSelector.log not rotating
lambay2000
Level 2
Level 2
Hi Joe,
CVDeviceSelector.log is not rotating after specifying file path and name after execuiting below command:
NMSROOT\bin\perl NMSROOT\bin\logrot.pl -c
for rotation:running logrot
D:\progra~1\cscopx\bin\perl D:\progra~1\cscopx\bin\logrot.pl -s
You would also need to reduce the maximum size of the file in logrot's config. Right now it's set to 1 MB. Therefore, the file will be rotated when it gets to 1 MB in size.
9 Replies 9
Joe Clarke
Post your NMSROOT/objects/logrot/logrot.conf file, and the output of logrot.pl -v.
Hey Joe,
Here are the logs attached,
appreciate ur help
I meant to run logrot.pl with the -v flag. That is:
NMSROOT/bin/perl NMSROOT/bin/logrot.pl -v
Here is the attaached.
Thanks Joe
The file isn't large enough to rotate yet:
Thu Nov 12 00:42:42 2009: INFO: Not archiving D:\program files\\cscopx\log\CVDev
iceSelector.log because it is not big enough.
file size = 737724, conf size = 1048576
It needs to get to 1 MB before it gets rotated.
Hey Joe,
Here is the attached print screen which is highlighting the log exceeded alert.
Thanks.
This means nothing. These sizes are arbitrary, and set in NMSROOT/conf/logstat.conf. You can change those sizes if you want. Logrot uses its own config file.
Hi Joe
As per ur previous mail i can change the size from NMSROOT/conf/logstat.conf but what about when it get full and shows red alert,same as now.I mean to say how i should rotate them,
Untill now i was rotating log file's as per my 1st mail procedure.
Thanks.
