CWCLI not exporting inventory
songj
I am not getting any luck on the cwcli export inventory command.
Here is the command I used:
# ./cwcli export inventory -u **** -f /tmp/inventory.out
This is the output:
<cwcli> * Warning * CWCLIFILE Environment variable not set.
Enter your password
SUMMARY
Failed: export: Could not obtain any devices.
Recommended Action:
1.Check whether devices are in RME.
I have checked the RME devices, there are hundreds of devices there.
Any idea?
nhabib
Level 9
Level 9
Try adding -device % at the end of the command. In other words:
/opt/CSCOpx/bin/cwcli export inventory -u **** -f /tmp/inventory.out -device %
nhabib
Level 9
Level 9
Great! It's working now.
Thanks a lot.
