DCR Slave authentication error
connie-yee
Frequent Visitor
Frequent Visitor
I am installing new CUOM and will be making it a slave to a master ciscoworks box that has been in the environment for over 5 years.  We were able to exchange the certifcates between the peer servers, but the problem is with the System Identity password.  No one remembers what that password is and we really don't want to change it in the Master server.  Is there log that can be read or decrypted to find out what the existing password is on the Master server?
Nael Mohammad
Level 11
Level 11
The system identity password is the same as the user id being used under Common Services ---> Server --> Security --> System Identity. If you want to change the password, go to Common Services --> Server ---> Security --> Local User Setup.  Or if admin, you will need to do this from the cli from CSCOpx/bin directory using the "resetpasswd.exe -f admin".
