Default Data Sending interval for Netflow Monitor in Cisco Router
What is Default Data Sending interval for Netflow Monitor in Cisco Router? As per our NMS OEM it should match with NMS server's data collecting interval which is 2min for our case.
as far as I recall, for version 5 and 9 it is 30 minutes. I think you can change the interval with the command:
ip flow-cache timeout <timeout>
Hi Georg,
I am unable to run this command in my router. Any other alternatives?
which router and IOS do you have ?
Hi Georg,
It's a Cisco 4300 series router(ISR4331/K9) with IOS version 17.6.3a .
