Default route to be distributed in ospf
meet_mkhan
Hi Experts,
I am in process of configuring ospf between dubai router and oman router.The problem
is the both routers have default to route to internet  0.0.0.0 0.0.0.0 214.42.x.x
Can i configure ospf on both routers if yes then how can i configure
any kind of information is appreciated.
Munawer Khan
17 Replies 17
Hi Dears,
   Thanks for all assistance.I am in process of using the network monitoring
   softwares but can anybody knows
   commands on cisco router,switch,cisco asa to check the same i mean related to monitor
    user traffic and cpu bandwidth etc
where something in your mind like
sh processes ?
  <1-4294967295>  Process Number
  cpu             Show CPU use per process
  history         display ordered Process history
  memory          Show memory use per process
  timercheck      Show processes configured for timercheck
  |               Output modifiers
sh memory ?
  allocating-process  Show allocating process name
  dead                Memory owned by dead processes
  debug               Memory debugging commands
  failures            Memory failures
  fast                Fast memory stats
  fragment            Summary of memory fragment information
  free                Free memory stats
  io                  IO memory stats
  multibus            Multibus memory stats
  overflow            memory overflow corrections
  pci                 PCI memory stats
  processor           Processor memory stats
  statistics          Mempool Statistics
  summary             Summary of memory usage per alloc PC
  transient           Transient memory stats
  |                   Output modifiers
sh interfaces fa0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0015.6260.3f7e (bia 0015.6260.3f7e)
  Description:
  Internet address is
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 43/255, rxload 42/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/75/29026385/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 8000 bits/sec, 12 packets/sec
  5 minute output rate 3000 bits/sec, 3 packets/sec
     1159982340 packets input, 4008215947 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     1787 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     532702931 packets output, 3247467049 bytes, 0 underruns
     0 output errors, 0 collisions, 40 interface resets
     30 unknown protocol drops
     0 lost carrier, 0 no carrier
Kind regards
Kai
Hi Kai,
                  I thank you very much for all the support.
                     Munnawer Khan
