Default route to be distributed in ospf
meet_mkhan
Hi Experts,
I am in process of configuring ospf between dubai router and oman router.The problem
is the both routers have default to route to internet  0.0.0.0 0.0.0.0 214.42.x.x
Can i configure ospf on both routers if yes then how can i configure
any kind of information is appreciated.
Munawer Khan
3 Accepted Solutions
It seems, that the serial interfaces are directly connected to the internet and the Dubai router can reach the Oman router and the other way aroud? If yes, see below
1. You have to create a tunnel interface on router dubei
     interface Tunnel 10
      description DUBAI_OMAN
      ip address 10.0.0.1 255.255.255.252
      cdp enable
      tunnel source
      tunnel source Serial 0/0/0
      tunnel destination 212.72.8.x
     exit
2. You have to create a tunnel interface on router dubei
     interface Tunnel 10
      ip address 10.0.0.2 255.255.255.252
      cdp enable
      tunnel source
      tunnel destination 213.32.x.x
     exit
3. You have to change the router ospf 10 at the Dubai router and include the tunnel network istead of the serial network
     router ospf 10
      router-id 10.254.0.1
      network 10.254.0.1 0.0.0.0 area 0
      no networ 213.32.x.x 0.0.0.0 area 0
      network 10.0.0.0 0.0.0.3 area 0       network 213.42.104.x 0.0.0.15 area 1
      redistribute static subnets route-map INTERNET-DUBAI
      default-information originate always
     exit
4. You have to change the router ospf 10 at the Oman router and include the tunnel network istead of the serial network
     router ospf 10
      router-id 10.254.0.2
      network 10.254.0.2 0.0.0.0 area 0
      no network 212.72.8.x 0.0.0.3 area 0       !
      network 10.0.0.0 0.0.0.3 area 0       !
      no network 192.168.11.0 0.0.0.255 area 1
      network 192.168.11.0 0.0.0.255 area 2
      redistribute static subnets route-map INTERNET-OMAN
     exit
5. You should now have an unencrypted connection between both routers.
no cdp isn't mandatory. It's sometimes only a nice feature to see the neigbours of your device, like "show cdp neighbours" .
Kind regards
Kai
where something in your mind like
sh processes ?
  <1-4294967295>  Process Number
  cpu             Show CPU use per process
  history         display ordered Process history
  memory          Show memory use per process
  timercheck      Show processes configured for timercheck
  |               Output modifiers
sh memory ?
  allocating-process  Show allocating process name
  dead                Memory owned by dead processes
  debug               Memory debugging commands
  failures            Memory failures
  fast                Fast memory stats
  fragment            Summary of memory fragment information
  free                Free memory stats
  io                  IO memory stats
  multibus            Multibus memory stats
  overflow            memory overflow corrections
  pci                 PCI memory stats
  processor           Processor memory stats
  statistics          Mempool Statistics
  summary             Summary of memory usage per alloc PC
  transient           Transient memory stats
  |                   Output modifiers
sh interfaces fa0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0015.6260.3f7e (bia 0015.6260.3f7e)
  Description:
  Internet address is
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 43/255, rxload 42/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/75/29026385/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 8000 bits/sec, 12 packets/sec
  5 minute output rate 3000 bits/sec, 3 packets/sec
     1159982340 packets input, 4008215947 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     1787 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     532702931 packets output, 3247467049 bytes, 0 underruns
     0 output errors, 0 collisions, 40 interface resets
     30 unknown protocol drops
     0 lost carrier, 0 no carrier
Kind regards
Kai
17 Replies 17
Kai Onken
I have two question:
  • Do you want to create a vpn tunnel over the internet
               See attached file INTERNET.TXT
    • Do you have a direct connection between the routers, e.g. darkfiber,...
                   See attached file DARKFIBER.TXT
      I think those samples should help, if I got your question right.
      In this sample is no focus set to scalability, like subinterfaces, VLAN, VRF, etc.
      In both samples the LAN client will have Interet access, if this should not happen, than remove the lines "redistribute static subnets route-map INTERNET-DUBAI" and "redistribute static subnets route-map INTERNET-OMAN"
      Hi Kai Onken,
      Thanks for your reply.Let me explain you my network setup
      R1 is in Oman
      ROUTER(R1) :SERIAL1(214.42.X.X/28)
      ETHERNET(192.168.14.1/24)
      defualt route via serial1 connected to lease line.
        R2 is in Dubai  ROUTER(R2) :SERIAL1(213.44.X.X/28)
        ETHERNET(192.168.10.1/24)
      default route via serial1 connect to lease line.
        Now i want to configure ospf point to point connectivity between Oman and Dubai
        so please assist me if it is possible to configure ospf between R! and R2?
      OSPF is an Interior Gateway Protocol (IGP) and it will not pass through a public network.
      You need to use some sort of tunneling mechanism (like a VPN or GRE tunnel).
      Hello Munnawer,
      Marvin is right. In this case, you've to use the INTERNET configuration and change the GigabitEthernet 0/1 to your serial connection. Than should your setup work. The point to point connection will be the Tunnel Interface. But notice that the two routers habe to "see" each other throught the internet to create a tunnel.
      If you want to do a VPN Tunnel you neet the hole INTERNET configuration. This connection will be encrypted
      If you only want a Tunnel, you could remove section starting with CRYPTO. This will be an unencrypted connection.
      You've to know, if you encrypt the connection, the bandwith could decrease, based on the routers you will use.
      Kind regards
      Kai
      Hi Dears,
                   Thanks for your replies.Kindly check the config below
      CONFIGUARTION AT DUBAI ROUTER:
      interface GigabitEthernet 0/0
      description LAN - Dubai
      ip address 213.42.104.x 255.255.255.0
      no shutdown
      exit
      interface Serial 0/0/0
      description Transfer to Oman via lease line
      ip address 213.32.x.x 255.255.255.252
      no shutdown
      exit
      interface loopback 10
      description Router ID | OSPF 10
      ip address 10.254.0.1 255.255.255.255
      no shutdown
      exit
      ip routing
      match tag 10
      exit
      ip route 0.0.0.0 0.0.0.0 interface Serial 0/0/0 tag 10 name "omanhost"
      router ospf 10
      network 213.32.x.x 0.0.0.0 area 0
      exit
      CONFIGURATION AT OMAN ROUTER:
      description LAN - Oman
      ip address 192.168.11.12 255.255.255.0
      no shutdown
      exit
      description Transfer to Dubai via lease line
      ip address 212.72.8.x 255.255.255.252
      no shutdown
      exit
      ip address 10.254.0.2 255.255.255.255
      no shutdown
      exit
      ip routing
      match tag 10
      exit
      ip route 0.0.0.0 0.0.0.0 interface Serial 0/0/0 tag 10 name "dubaihost"
      router ospf 10
      exit
      Still i cant see ospf in Routing Table there is only default route via serial 0/0/0
           interface Tunnel 10
            cdp enable
            tunnel source
           exit
           interface Tunnel 10
            cdp enable
            tunnel source
           exit
           router ospf 10
           exit
           router ospf 10
           exit
          I am Getting error while enabling cdp on tunnel interface
      DUBAIHOST(config-if)#cdp enable
      % CDP is not supported on this interface, or for this encapsulation.
      So is it mandatory to enable cdp.?
      Kind regards
      Kai
      Hi Kai Onken,
      I Thank you very much for all the assistance now every thing is working fine.
      i can see the ospf routes in Routing table along with default route.this time i wll choose your answer
      is perfect correct.
      Dear Kai Onken i need one more favour from your side
      do you any good network monitoring commands in cisco or any software to monitor all things like
      router bandwidth how much used, free and which application uses how much bandwidth
      router,firewall,switches cpu load,each user how much bandwidth utilizing and what kind of services
      users are using i mean all things I want to monitor.
              Thanks agian for your support .
      Munnawer Khan.
      We're using Nagios at our office. If you don't need any kind of support, you could choose the opensource version
      http://www.nagios.org/ additional you can check http://exchange.nagios.org/ for plugins. This should help you.
      At the configuration advise you to use the encryption on the Internet connection form the sample at the top.
      Kind regards
      Kai
          I am installing this software and i will check how it works in my network.
           Do you know any cisco commands on routers,switches and cisco asa to do same thing i mean monitoring
            users particularly bandwidth utilization.
      Munnawer
          My friend this nagios software is only for CentOS and Ubuntu servers i wnat
          software on windows platform like windows 2000,2003xp etc.
      Munnawer
      you could try e.g.
      Kind redards.
      Kai
      For performance management you can run the open source Cacti on Windows (although most people run it on Linux, as with Nagios mentioned earlier). That will give you high level - e.g. bandwidth used by an interface.
      If you want to drill down to see user level utilization you will need to use Netflow on the routers exporting to a collector on a server. What's Up Gold can be a Netflow server. You can also use a free tool like ntop but I don't think it is available on Windows.
