05-03-2005 11:11 AM
I have setup RME to deleted config files that are older than 30 days and to just keep 5 version of each it. However, under /var/adm/CSCOpx/files/archive/config I still have config files from many years ago. I had also tried Delete Change History under RME/Admin/Change Audit.
What else is required to remove all these old archive config files? .
05-03-2005 12:08 PM
This is what I've done on my server, and it works:
RME -> Administration -> Change Audit -> Delete Change History
Select All Devices
Keep all the default values, and enter a Date Range of Older than 30 Days
Click on Next
Run Immidiately, then go ahead and schedule it to run weekly.
This will not delete the files, but next time a purge occurs, it should.
05-03-2005 04:03 PM
I tried your suggestion - i.e run the job immediately and then scheduled the job to occur every day at 3:30pm but the old config files are still there. I check the ChangeAudit.log and found out that 0 records were deleted for the 3:30pm daily job.
