Design network Firewall ...
yann.boulet
I am looking for a software better than visio to design my network and update it everytime, i think MS Visio is not the better one, if it's possible do you know if i can use autodiscovery tool, i would like to use a software which can take cisco pix configuration file to draw the network.
Thank you for your help
Tony.henry
yann,
Visio is pretty popular but if you want to try something else, Netviz is out there as well.
I'm not sure there is anything out there which will meet what your trying to do.
Tony
ccbootcamp
Level 7
Level 7
There are some network management tools that have auto-discovery:
Whatsup Gold
Solar Windows
ManageEngine (OPManager)
Cirrus Config Manager (also from Solar Winds)
I believe you can download demos of each of them.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
