design network topology and upgradation from 1G to 10G
Daps
we are in process to upgrade Network bandwidth from 1G to 10G with eliminating single point of failure.  Attached diagram for your reference.
Point 1 - Earlier there is only one switch (L2) and single port of Router. Now, we use ASR Cluster and Stack switch for high availability and redundancy.
PLAN - we are planning to create ETHERCHANNEL on both end. (ASR and StackSWITCH)
Point 2 - With the help of CHECKPOINT support team, We are planning to create Bond of 2 Ports and connect each port to both the Stackable switches.
PLAN - We are configured the ports as Trunk on switches.
Point 3 - ACI Side, We are creating VPC domain with 2 Leaf switches and connect cables as per diagram.
Whether this scenario works or not and please share any suggestions.
0 Replies 0
