Device credentials problems
martin.wigertz
Community Member
When we are adding a device in Ciscoworks LMS 2.5 that are running Tacacs we are experiencing problems with device credentials. When we are running a "Credential verification Report" we get "incorrect" in the "telnet" field and in the "enable by telnet" field we get "did not try"
Any suggestions on why this happends?
frankzehrer
Level 8
Level 8
Hi Martin,
please setup in "Common Services" -> "Device and Credentials" -> "Device Management" the access credentials for the devices.
Tick the group of devices or browse to the single device and then press the button "Edit".
A new windows appears. Follow the instructions and insert the matching passwords.
Your failure happens if no credential is setup. After the credential setup open the RME and run the report again.
Cheers
Frank
netnut
Community Member
Beware of TACACS it responds with PASSCODE, not PASSWORD. Passcode is not a valid response according to the doc I read.
The PASSCODE issue is resolved in RME 4.0.1 (see bug id CSCsa88849)
