Device Discovery Notification LMS
ahurtadove
Hi all, I'm kind of new in CiscoWorks so there are many things that I don't know if it is capable of doing.
First, I would like to know if there is any place where I can see the new devices discovered in the last discovery job.
Second, When that discovery job is finished and the it actually found something, can it send mails to the admins?
Thank you very much for your kind support.
Gaganjeet Chug
Level 4
Level 4
Both of the above option is possible. When ever the last discovery completed (Ad-hoc), it will always show the "new devices added to DCR" under caption :- Devices Newly Added to DCR.
Also you can configure your email address while configiuring the device discovery so that it will send you the notification with the details when the discovery job started and ended.
Here is very good doc which help you to understand Device Discovet better penned by Joseph Clarke himself
https://supportforums.cisco.com/docs/DOC-9005
hope it helps,
Gaganjeet
