device discovery seems to freeze
desrochj1
Sometimes it's seems that my device discovery freeze...
(the job never ends, always showing running...
sometimes device discovery was started 1 day before and it's still showing ..running...
that is not normal.... i try to stop the discovery with the interface and it doesn't work too.
i need to reboot to start another discovery.
I am using LMS 3.1
Can you help me on this
thanks
5 Replies 5
Martin Ermel
It seems you are seeing BugID CSCsv42110:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsv42110
CSCsv42110 Bug Details
Discovery hangs sproadically
Symptom:
CSDiscovery does not finish and keeps hanging
Conditions:
CS 3.2
Workaround:
n/a
According to jclarke it is fixed in LMS 3.2 - and TAC should have a patch for LMS 3.1
Even if you cannot stop discovery from within the GUI, you should be able to stop it by executing
     pdterm CSDiscovery
form the command line (Dos - Box or solaris shell) without restarting LMS or  rebooting the server
In Common services, i see that i have Ciscoworks LMS 3.1
and Common Services is at 3.2.0
Do i need to upgrade to LMS 3.2, even if common services module  is at 3.2.0 ?
Common Services (CS) 3.2 is not the same as LMS 3.2. Each application in LMS does have its own version number;
LMS 3.1 does have CS 3.2
LMS 3.2 does have CS 3.3
You have 2 options, open a Service Request with Cisco TAC to get the patch or update your LMS version from LMS 3.1 to 3.2. You can download LMS here:
http://www.cisco.com/go/lms
then click on "Download Evaluation Software"
to get the DVD media, enter your service contract number here:
http://www.cisco.com/upgrade/
your current License does work for LMS 3.2
hello,
can i install lms 3.2 directly on top of lms 3.1 (execute setup.sh)
thanks
yes you can ..
It is always a good practice to make a backup of the current installation before starting the update;
Depending on the size of the network and the customizations you have yet done you could also consider an uninstallation and starting from scratch (LMS 3.2 is a full version).
these are the typical steps to perform an upgrade:
- make a backup
- stop the processes (/etc/init.d/dmgtd stop)
- verify that there is no process running (ps -ef | grep -i CSCO)
- verif that all necessary solaris patches are installed on the system as mentioned here:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1099303
- execute the setup.sh
