Device Fault Manager SNMP Trap Port
scornish1
All,
During installation, I was prompted to use a different port for SNMP traps because there was already a process using UDP 162.
The process was eventually disabled and now I'd like to reconfigure DFM to bind to UDP port 162 instead of port 9000.
What's the process for reconfiguring DFM to bind to UDP 162 to receive SNMP traps?
Gaganjeet Chug
Level 4
Level 4
You can change it back to port 162 from DFM > Configuration > Other Configuration > SNMP Trap recieving >
Gaganjeet
Gaganjeet Chug
Level 4
Level 4
Gaganjeet
thank you
