08-03-2009 02:25 AM
LMS - 3.0,
CS - 3.1.0
RME - 4.1.0
After importing devices using CSV, following devices are still showing as UNKNOWN with a '?' symbol:
ASA, FWSM, security-Contexts on FWSM, CSS, SAN.
Switches and routers are fine. I tried for device pkg update in CS and RME, but it says all available pkgs are already installed.
Need help. thanx in advance.
08-03-2009 08:23 AM
You need to upgrade to LMS 3.0.1, then you can apply updated device packages. The download for LMS 3.0.1 can be found at http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 .
08-05-2009 06:37 AM
Upgraded to LMS 3.0.1, still same device status.
'?' for the same devices.
