Device Templates
vishal.rane
Level 3
Level 3
hi
Do Cisco provides device templates i.e Routers / Switches / Firewall / Wireless Lan controller / AP for Cisco Prime Infrastructure 2.0
Minimum must required configuration on devices to be detected by PI
thanks Vishal
AFROJ AHMAD
Hi VIshal,
Go to Design >configuration >feature design >CLI template   >> SNMP template
similarly , you can find the other necessary templates there.
Thanks-
Afroz
****Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
