Device Update Failure
jamie.gleeson
Hello, we are running LMS 3.0.1.  When I attempt to update the devices for RME I received the following error messages.
Number of Packages Selected for Install : 82
For Product(s) : Resource Manager Essentials
Install Invoked by user : admin
The Package(s) Selected for Install :
ACE, ASA, ASR, Cat2300, Cat2960, Cat3560, Cat3750, Cat4000IOS, Cat6000IOS, CatGL3, CBS3000, CE500, CRS, GenericVendorDev, GSS, IE3000, LibCommon, LibInventory, LibSwim, MCS, MDS, MetroSwitch, MWR, NAM, Nexus, ONS, Pix, Rtr12000, Rtr1800, Rtr1900, Rtr2900, Rtr3200, Rtr3800, Rtr7000, Rtr800, SharedCdaGSS, SharedCdaWLC, SharedCfgEditGSSDiff, SharedCfgEditGSSNegation, SharedConfigNegatCERule, SharedConfigNegatGSSRule, SharedConfigNegatIOSXRRule, SharedConfigNegatWLCRule, SharedCredentialUpdaterACERule, SharedCredentialUpdaterCERule, SharedCredentialUpdaterGSSRule, SharedCredentialUpdaterIOSXRRule, SharedCredentialUpdaterWLCRule, SharedDcmaCE, SharedDcmaGSS, SharedDcmaIOS, SharedDcmaIOSXR, SharedDcmaPIX, SharedDcmaSC, SharedDcmaSS, SharedDcmaWLC, SharedHelpGSS, SharedHelpSS, SharedHelpWLC, SharedInventoryCatIOS, SharedInventoryCatSwitch, SharedInventoryCE, SharedInventoryGSS, SharedInventoryMDS, SharedInventoryRouter, SharedInventoryWLC, SharedNetconfigIOSXR, SharedNetconfigSS, SharedNetconfigWLC, SharedNetshowWLC, SharedSwim2900XL, SharedSwimACE, SharedSwimContentEngine, SharedSwimGSS, SharedSwimIOS, SharedSwimIOSXR, SharedSwimMDS9000, SharedSwimOE, SharedSwimPix, SharedSwimWLC, WLC, WLSE
WARNING :  CE500(4.4):Consistency check failed for base package SharedNetconfigContentEngine
WARNING :  GenericVendorDev(1.1):Consistency check failed for base package SharedNetconfigGeneric
WARNING :  ACE(1.2):Consistency check failed for base package SharedNetconfigACE
ERROR: Error while installing (Cat3750): D:psu_download
meCat3750.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (SharedDcmaGSS): D:psu_download
meSharedDcmaGSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (MWR): D:psu_download
meMWR.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedSwimIOS): D:psu_download
meSharedSwimIOS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.35
ERROR: Error while installing (ASR): D:psu_download
meASR.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.37
ERROR: Error while installing (WLSE): D:psu_download
meWLSE.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedCfgEditGSSDiff): D:psu_download
meSharedCfgEditGSSDiff.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (Rtr800): D:psu_download
meRtr800.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.33
ERROR: Error while installing (SharedNetshowWLC): D:psu_download
meSharedNetshowWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (MDS): D:psu_download
meMDS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedInventoryCatSwitch): D:psu_download
meSharedInventoryCatSwitch.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedCfgEditGSSNegation): D:psu_download
meSharedCfgEditGSSNegation.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (IE3000): D:psu_download
meIE3000.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (ASA): D:psu_download
meASA.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (CRS): D:psu_download
meCRS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedSwimContentEngine): D:psu_download
meSharedSwimContentEngine.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedHelpGSS): D:psu_download
meSharedHelpGSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedInventoryGSS): D:psu_download
meSharedInventoryGSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedSwimWLC): D:psu_download
meSharedSwimWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (LibSwim): D:psu_download
meLibSwim.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.31
ERROR: Error while installing (MCS): D:psu_download
meMCS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedSwim2900XL): D:psu_download
meSharedSwim2900XL.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (SharedNetconfigSS): D:psu_download
meSharedNetconfigSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (SharedSwimACE): D:psu_download
meSharedSwimACE.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (SharedDcmaPIX): D:psu_download
meSharedDcmaPIX.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedCredentialUpdaterIOSXRRule): D:psu_download
meSharedCredentialUpdaterIOSXRRule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedConfigNegatIOSXRRule): D:psu_download
meSharedConfigNegatIOSXRRule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedSwimPix): D:psu_download
meSharedSwimPix.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedInventoryMDS): D:psu_download
meSharedInventoryMDS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (LibInventory): D:psu_download
meLibInventory.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.35
ERROR: Error while installing (Rtr1900): D:psu_download
meRtr1900.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.34
ERROR: Error while installing (ONS): D:psu_download
meONS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (Rtr2900): D:psu_download
meRtr2900.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.34
ERROR: Error while installing (CatGL3): D:psu_download
meCatGL3.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.26
ERROR: Error while installing (Rtr1800): D:psu_download
meRtr1800.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedDcmaCE): D:psu_download
meSharedDcmaCE.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedInventoryCatIOS): D:psu_download
meSharedInventoryCatIOS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.32
ERROR: Error while installing (SharedSwimGSS): D:psu_download
meSharedSwimGSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (SharedCredentialUpdaterGSSRule): D:psu_download
meSharedCredentialUpdaterGSSRule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedCredentialUpdaterCERule): D:psu_download
meSharedCredentialUpdaterCERule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedCredentialUpdaterWLCRule): D:psu_download
meSharedCredentialUpdaterWLCRule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (Rtr3800): D:psu_download
meRtr3800.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (CBS3000): D:psu_download
meCBS3000.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedConfigNegatGSSRule): D:psu_download
meSharedConfigNegatGSSRule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedHelpSS): D:psu_download
meSharedHelpSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedConfigNegatWLCRule): D:psu_download
meSharedConfigNegatWLCRule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (LibCommon): D:psu_download
meLibCommon.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (Cat6000IOS): D:psu_download
meCat6000IOS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedNetconfigIOSXR): D:psu_download
meSharedNetconfigIOSXR.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (MetroSwitch): D:psu_download
meMetroSwitch.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (Nexus): D:psu_download
meNexus.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.31
ERROR: Error while installing (WLC): D:psu_download
meWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.37
ERROR: Error while installing (NAM): D:psu_download
meNAM.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedDcmaIOS): D:psu_download
meSharedDcmaIOS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.29
ERROR: Error while installing (SharedSwimOE): D:psu_download
meSharedSwimOE.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedCredentialUpdaterACERule): D:psu_download
meSharedCredentialUpdaterACERule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedCdaWLC): D:psu_download
meSharedCdaWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (Rtr3200): D:psu_download
meRtr3200.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.30
ERROR: Error while installing (SharedInventoryCE): D:psu_download
meSharedInventoryCE.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedConfigNegatCERule): D:psu_download
meSharedConfigNegatCERule.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedDcmaWLC): D:psu_download
meSharedDcmaWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedSwimMDS9000): D:psu_download
meSharedSwimMDS9000.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.31
ERROR: Error while installing (Cat2960): D:psu_download
meCat2960.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.35
ERROR: Error while installing (SharedDcmaSS): D:psu_download
meSharedDcmaSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (SharedSwimIOSXR): D:psu_download
meSharedSwimIOSXR.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.37
ERROR: Error while installing (Pix): D:psu_download
mePix.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (Rtr12000): D:psu_download
meRtr12000.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (SharedDcmaIOSXR): D:psu_download
meSharedDcmaIOSXR.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.24
ERROR: Error while installing (Rtr7000): D:psu_download
meRtr7000.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (GSS): D:psu_download
meGSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.27
ERROR: Error while installing (SharedDcmaSC): D:psu_download
meSharedDcmaSC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedHelpWLC): D:psu_download
meSharedHelpWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedInventoryWLC): D:psu_download
meSharedInventoryWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (SharedNetconfigWLC): D:psu_download
meSharedNetconfigWLC.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.23
ERROR: Error while installing (Cat3560): D:psu_download
meCat3560.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.35
ERROR: Error while installing (Cat2300): D:psu_download
meCat2300.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (Cat4000IOS): D:psu_download
meCat4000IOS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.30
ERROR: Error while installing (SharedCdaGSS): D:psu_download
meSharedCdaGSS.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.25
ERROR: Error while installing (SharedInventoryRouter): D:psu_download
meSharedInventoryRouter.zip cannot be installed because, the current mdf version:1.22 is LESS THAN the minimum required mdf version:1.30
No package(s) to install for : Resource Manager Essentials
Any help is appreciated.
Jamie
AFROJ AHMAD
Hi Jamie,
Try Updating the MDF Version first to the Latest..
go to Common service > software center > device update >> check the check box for cisco works common service >> click on update..
--One suggestion :
If you can Upgarde the cisco works to 3.0.1 that would be great and you need not to get a new License for LMS 3.2 your Existing license should just work fine...
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
