Upgrade to LMS 3.2.1 from LMS 3.2.0?
raza555
Level 3
Level 3
HI,
I am upgrading the LMS 3.2.0 to LMS 3.2 SP1 software and also RME 4.3.0 to RME4.3.1. Do I need to add further patches to make CiscoWorks up to date.I know that LMS 4 is released but currently we are not planning to buy it.
LMS 3.2 supported OS
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1099303
Prime LMS 4.3.1 supported OS
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/install/guide/prereq.html#wp1119955
Gaganjeet Chug
Level 4
Level 4
No upgrading to LMS 3.2 SP will be sufficient and is the last software upgrade till this date. The other things that need to be upgraded is DEVICE PACKAGES. Kindly make sure you are running upto date device packages for Common Services (for MDF) and then RME , CV and DFM.
That will make your software upto date with the Cisco.com till date.
Many Thanks,
Gaganjeet
Gaganjeet Chug
Level 4
Level 4
Many Thanks,
Gaganjeet
