01-22-2008 08:24 AM
Hi there again,
Started off on a fresh install of LMS 3.0.1 on Windows 2003 Enterprise box. I'm running into an issue where devices within DFM 3.0.2 are not getting past the learning state (stuck at 10%). Also, if I try to delete the devices, then they stay in the pending state unless I try rediscovering them.
Anyone else has experienced this type of issue?
Solved! Go to Solution.
01-22-2008 08:48 AM
look at the following thread how to trobleshoot this issue:
01-22-2008 08:48 AM
01-22-2008 09:50 AM
Thanks for the threads. Based on them, I believe I have resolved the problem. Specifically I needed to append the DNS suffix to the hostname under:
My Computer > Properties > Computer Name > Change > More
09-04-2008 03:45 AM
Does same in Solaris 3.1.
