dfm alerts for operationallydown
secureIT
Level 4
Level 4
Hi All,
im having lms 4.2.2 and monitoring a cisco 7600 router interface ten gigabit ethernet x/x under dfm. When ever the interface is down due to any media issue i am not getting any alerts in dfm., the interface used to go down for more than 10 minutes. I am able to do an snmpwalk to this interface when the interface was down and getting the value as 2(for down). I am getting other information and configuration mode alerts in dfm for this device. please help to fix the problem.
Martin Ermel
Can you verify that the interface is managed for monitoring the faults? Go to
Monitor > Fault Settings > Setup > Fault Device Details
    select the device in the "Device Selector" and click "View"
    in the table that opens, there is a column "Device Name"; in this column, click on the device name and a new window opens with "Device Details"
    search the interface and check, that the mangement state is "true"
