DFM and interface status?
marktop2
I have the following problem with DFM 2.0.2 on Windows:
After initial successful discovery in CM I get many alarms: "interface unresponsive", although "admin state" of relevant interface is "down".
I guess the expected behaviour should be to ignore such interfaces (administrativly down - shutdown) regardless of state of line protocol.
Once suspended/resumed/cleared the alarms reappear again and again.
Questionable interfaces are serial interfaces on 2600/3600 router.
Thanks for answer
Mark
wong34539
Level 6
Level 6
Try deleting the devices and then re-add the devices.
Thanks for answer!
I did deleting and rediscovery already, just the same result!
Any more ideas?
mark
