DFM stuck in 10%
lorcs
I have just installed LMS3.0 in a customer network. The DFM does not work as the devices imported from DCR is stcuked in the listening stage. My DFM version is 3.0.0 and I have been following the forums thread to resolve the problem but was not successful. The hostname resolution is good and I even resintalled the DFM module but still have no luck. Attached is the pdshow and an extract from DFM log. I hope if someone can provide the hints for me to fix this problem as soon as possible.
Joe Clarke
You're seeing a known bug (CSCsm04957). You need to upgrade to LMS 3.0.1 then go to DFM 3.0.4. To download LMS 3.0.1 to go http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 . Once you're on LMS 3.0.1, you can download DFM 3.0.4 from Common Services > Software Center > Software Update.
