DFM Unknown Devices - please help
Vitaly Razgulov
Good day.
I have got LMS 3.2 (DFM 3.2.0).
My router 3900 Series (RFC1213-MIB::sysObjectID.0 = OID: CISCO-SMI::ciscoProducts.1041) in DFM is unknown device.
In others modules of LMS (CM, RME and others) is OK.
Why?
Help please.
Sorry, but I can't open this URL...
Error 403- Forbidden File or Application.
Can you help me and to past here some part of this html page?
I was fooled by the table that doesn't fit on my screen
I thought it said not supported but I was a coulumn off
Apparently there is an update you can download from CCO
You need a cco login of course
Device Type     Device Name / Modules Supported     sysObjectID / Vendor Type     Minimum Software     Supported Version (CM)     Topology (CM)     VLAN Mgmt (CM)     LANE Mgmt (CM)     VNM (CM)     User Tracking (CM)    Supported Version (DFM)
DFM1.x Class (DFM)
    Supported Version (RME)     Inventory (RME)     Config Mgmt (RME)     Software Mgmt (RME)     Package Name (CV)     Package Version (CV)
Cisco 3900 Series Integrated Services Routers     Cisco 3945 Integrated Services Router     1.3.6.1.4.1.9.1.1041     15.0(1)M [RME, CM]     5.2 (Device Updates 4.0)7     Yes     NA     NA     Yes     NA    3.2 (DeviceUpdates 2.0)26     Not Supported     4.3 5     Yes     Yes     Yes     Rtr3900      1.1
26. DFM Device Update for this specific device support is available at:http://www.cisco.com/public/sw-center/index.shtml.
Cheers,
Michel
Thank you, Michel.
